I have seen some people make inserts for their doors does anybody just sell them?
one member said he drilled holes and rivetted his to his door so u wont have anything to get hurt on when u put it on thereHow did you fasten them? Self tapping screws right to the plastic? I've been thinking about doing the same and having them dipped in camo to match.
Can you post pics of the inside of the door panels? I just want to see what you did and how it looks.Like stated above, you can get them for $160.... or for $150 you can get a .025 thick 10' x 4' sheet of black or high polish aluminum diamond plate from onlinediamondplate.com and have enough to make your own (just rivet to the door). You'll also have enough left over for a roof... or two. I made the door inserts, roof, and still have enough left over to build a dry box for the entire bed. See pics at the link below. Chris's 850i Gator Board on Pinterest
No problem at all.... as soon as I get it back. It's been at the dealership for a week. Engine is knocking.Can you post pics of the inside of the door panels? I just want to see what you did and how it looks.Like stated above, you can get them for $160.... or for $150 you can get a .025 thick 10' x 4' sheet of black or high polish aluminum diamond plate from onlinediamondplate.com and have enough to make your own (just rivet to the door). You'll also have enough left over for a roof... or two. I made the door inserts, roof, and still have enough left over to build a dry box for the entire bed. See pics at the link below. Chris's 850i Gator Board on Pinterest
Good idea.....I rest my knee on the door.I made my door inserts from 3/8" smooth plywood and had a local sign shop make some decal to match the OEM scheme. I then upholstered the inside with 3/4" foam and vinyl
That get's a 10 out of 10 in my books, that looks pretty B.A.
Want to make me a set, no powder coat required.I made my own door inserts. Bought a 1/2 sheet of 1/8" aluminum for $50 . Traced and cut the panels out and had them powder coated black for $15 each.Total cost of $80 and I still have enough aluminum for 2 more sets.
