Been continuously having electrical problems, every once in a while in deep water my RSX will get a hiccup and die only if you put the pedal to the floor. Like I said its really sporadic and I'm not really too worried about it but was just wondering if anyone else experienced something like this. Now, my main problem that seems to be a consistent plague on my machine is the stator/regulator/charging system. At first it was just mud in the fuse for my regulator and all you would have to do is wiggle the fuse and it'd make connection again and keep working, so then I added some mud flaps and whatnot around the front compartment to seal off the fuse box from any possible mud. Now wiggling the fuse doesn't even work, I've cleaned all my battery connections and checked a lot of different connections and still no luck. The machine will run normally at 12.2 volts and once I turn my headlights on (not even the spot lights) it will run at 11.8 volts which tells me it isn't even trying to charge. I've talked with my dealer and they've got it on the list to get in the shop but with spring rolling around they're busy with oodles of mowers and made it sound like it could be a while till mine gets in. Since my spring fever is kicking in and I really wanna get riding I was wondering if anyone had any ideas to try in the meantime. Any responses are appreciated.
