Only reading 2 volts going to the fuel pump and if I hook up 12 to the pump it runs. Under the hood the small red wire on the black plug below the relays only reds 2 volts. Any help?
Thanks anyway Brad I did figure out that the problem is with the relay module.
was the ecu the problem or the relay under the hood for the fuel pressure?Hate spell check
