RSX850i Trail..problems shifting.. some times when you shift gears it does not want to go into gear completely or does not want to go into gear at all. Then there's the times it sounds like a meat grinder and will not go into gear. Other times you can't get it out of gear without problems. Approx. 250 miles on the unit. Anyone out there have any of these issues? Any ideas on a fix? Next stop a call to the dealer. :confused: :mad:
Primary clutch
This is a fairly common issue. If under warranty, take to your dealer as I understand the replacement part is a different # than what comes on the machine?
I was told this by my salesman before the sale so I'm not 100% if he was telling the truth.
Shifting problems
My Trail did the same, it was cured by the dealer with a cable adjustment.
I had the same issue....As soon as it got to riding temp. the clutch would stick and could not shift into any gear. Dealer replaced the Primary Clutch and all seems to be fine now.
I had very similar issues with my RSX Trail, ended up having both the primary and secondary clutch replaced and seems to be working good so far. Good Luck
