1 - 8 of 8 Posts
Hi all,
I've notiched this ticking sound when the engine is cold. After 3-5 minutes it's gone. It's a 2011 825i with 4000 on the ODO.
Hope this video works :)
825i Engine ticking sound
Please advice.
Thank you.
While I don't have experience with this motor, the sound would be enough for me to investigate further. Maybe check the valve lash as starters and make certain there are no broken valve springs or sticking valves.
Reactions: Pahawi
Thanks guys - very kind of you. Any lead on which assortment of shims I should look for?
Thanks again.
I haven’t done this in over six years so I don’t remember the available thicknesses and I don’t remember buying an assortment. I got several of each thickness from Deere and they weren’t cheap. I wouldn't be surprised if there is now an aftermarket source. You might try googling something like “Chery engine parts.”
Hope this helps,
Doc
After reading that the sound goes away after a few minutes I think I wouldn’t adjust them. I would find the oil pressure sender and install a mechanical oil pressure gauge. This sounds like an oil pressure problem.
Discussion Starter · #8 ·
Thanks Doc - I talked to a mechanic today and that's his first thought too. He'll come and look into it soon, I hope. We'll see what he finds.... :)
Thanks again.
1 - 8 of 8 Posts
