I have an early 2000s 4x2, and it acts like it is not getting fuel, I've cleaned the inline filter, and is seems to be pumping gas but the stream is very weak. Some days it starts right up and will go all day some days it wont start at all. I don't want to just replace parts any ideas? thanks chris
Do you care to list what diagnostics you’ve done so far to conclude it is a fuel issue and not something else?
battery is good, visual hot spark, good compression (blows your thumb off the seat when spun over). always use fresh non ethanol gas. I cant think of anything else, it was running fine up till this episode.
Thanks for confirming you have good spark and compression.
Since I don’t own one of these machine’s,is it carb for FI?
If carb, is pull the bowl to confirm fuel and to check how much crude is in the bottom.
if fuel injured, I’d verify integrity of fuses and to make certain there is no corrosion where fuses plug into. If ok. Check to see if FI are pulsing.
