Lots of oil
So I've went through about 25 gallons of oil, front an rear dif, trans, 5 oil filters 5 gallons of diesel 5 gallons of regular gas 2 spark plugs 2 o2 sensor air filter fuel filter
Flushed the dif w diesel 3times blew out after every time filled with cheep diff oil spun the tires drained it out blew it out. Filled w john deer diff oil.. Blown out vent lines
Drained trans, filled w cheep ATF Blew it out after every drain then filled with john deer trans fluid . Blew out the vent line
Took the exhaust off drained water , tilted muffler so it could drain over night. Put it back together new o2 sensor
Took the fuel tank off drained it put a gallon in it shook it up drained it blew out the vent lines
Drained the clutch housing took the cover off cleaned it out belt look good put it back together
Moved all the vent lines up the roll bar
Drained the oil pulled hoses blew them out blew the aluminum lines to the oil cooler changed oil filter used cheep oil ran it for 15 to 20 mins after every change, after the forth time oil looked good put the john deer 0w-40 In it. Ran it for half a day changed all the fluids again
Went though every connection cleaned w electric component cleaner
It only has 200 miles on it 2013rsx850i trail 27 rip shaw glass windshield w wiper 2 inch lift rear poly Shield
For sale has been swamped J/K!!
will see how it goes the next few months
