Voltage doesn't tell you much about a battery. Hook up your volt meter and turn the key to start and see what the voltage does. Or, take the battery to an auto parts store and have them load test it.
How old is your machine?
First, make sure your air filters are clean so the engine isn't starved for air. Next, I suspect a fuel problem for it dying several times after starting. An an air leak in the fuel system is my first guess. Also check for bad high pressure pump and/or injectors but that gets expensive fast so make sure you rule out a simple air leak before getting out the credit card.
