Is it just me or is the RSX a little clunky going from neutral to H or R? I recall a gator that used to run around the campground we were at and it constantly made horrible grinding noises. This scares me a bit because sometimes the RSX seems stiff to shift then if its not all the way in gear it grinds too. So I'm very careful now putting it into H or R and very slowly touch the gas pedal to make sure it engages. Sometimes it seeems like if the machine rocks forward or back a little bit then it slides right into gear. Is this how it is supposed to be? Is it just because it's brand new?
