1 - 2 of 2 Posts
I can start my 15 year old turf gator but it will not go into the upper gear. The battery seems good. I replaced the coil about a year ago and at the same time put in a new demand pump. Up till no problems at all. Any help appreciated
This sounds like a clutch issue, have you removed both clutch’s throughly cleaned with hot soapy water and or non chlorinated brake cleaner followed by compressed air? You will need to remove the cover on the primary clutch in order to clean properly. Once the cover is off closely inspect the rollers for flat spots or abnormal wear.
1 - 2 of 2 Posts
