1 - 20 of 20 Posts
the iac is open and stays that way. its a new one old one worked the same it idles at 3300 wont come down .
Have you check voltage at the connector of IAC. Remove intake hose and check the butterfly is going shut ,have seen shaft worn binding up.
no butterfly is closed its the idle air moter is not miving right its a new one what the bolts at plug do u know! it moves to shut at start up and opens to 3200 rpm after
iam going to try resetting the ecm buy removing the neg a few minets someone said just touch the neg to pos a split second and hook it ip but i font wana do that
Which bolts are you asking about. Did you check to see if you have a vacuum leak, hose or gasket. have seen bolts missing holding throttle body.
Discussion Starter · #7 ·
have not looked hard for vac leak will do . i plug that iac hole before butterfly with my finger it idles hright down
Check voltage at iac wire, white,blue wire, also voltage green ,blue red wire 12volts when key on. Possible bad ECU
Discussion Starter · #11 ·
no air leaks. if i place my finger on the iac intake hole on throtle body before butter fly idle comes down
What was the IAC part number MIA 12803, Even though a new IAC could you ohm the terminals , the 2 outside ,then the 2 in side, see the resistance. Did you check on the throttle body for wear or deposits where the IAC makes contact inside.
Discussion Starter · #14 ·
Ill check inside and clean it up. both iac work on another mechine. its closed when key turns i hear it moving and opens as soon as its running houng from 850 rpm to 3400
Discussion Starter · #16 ·
seems to be a rare event as i cant find a thing on it. there is a jd solition i see if i can get it printed out
1 - 20 of 20 Posts
