Every time my motor gets wet it loses power or dies.. it is a carb 16 hp vangaurd... with solid state ignition off the flywheel mags is this normal... some engines can run under water with snorkles... I'm just not familer with ignition on a small eng ine
Welcome to the forum!!!!!!!!1
It can run right under water if it is snorkeled right and the carb is set up right. Not the best thing to do, but you know we like to water ride, LOL!!!!!!
Hopefully someone will come along here and help better than I can.
I have the same problem with mine. I'm runnin 29.5 terminators and thought that it might just be the tires diggin in but there's no way that it could be the tires bogging it down. I'm gunna try putting exhaust on it with a programmer and see if it helps
