1 - 8 of 8 Posts
First pic looks like milkweed pods and chipmunk fur? Should be sticky if milkweed
Can you pull the white fibers apart if not maybe belt?
I found some funky stuff and I’m freaking a little. The stuff in the first picture is what I pulled from the opening in the second picture. It is like fiberglass of some sort
טי️×Â� ×™️רוש️למי️;95513 said:
I atleast know its not an exploded belt.
Looks more like something tried to make a nest
I can pull it apart, it is fiberglass. So you think it not related to the gator itself? It did look a little like a nest. What happens when a belt explodes?
There is no fibreglass anywhere on any gator.
If a belt "explodes" its mainly rubber pieces and strands of flax rope.
I have seen them get so worn or jump over the edge so they get chewed up and eaten by the vario making it look like the vario had a fight with a ball of yarn
Discussion Starter #8
No I didn't pull it apart, after hearing there no fiberglass on the unit and the more i look at it the more i do believe it was a nest. I'll probably pull it apart this winter/spring.
Thanks for the help everyone!!
1 - 8 of 8 Posts
