1 - 2 of 2 Posts
above 25 mph the driver window has a whistle.is this a common problem? thank you
Not that I heard. Make sure the weatherstripping is affixed continuously. JD typically uses two sided tape and slaps the stuff in. If you have loose weatherstripping, pull it out and permanently attach it with Goop. The door strip is a particular lousy job by JD. Before you start tossing glue around, use some playing cards as shims and wedge around the weatherstripping to see if a minor compression will take care of it. Smashing a piece of copper wire flat and gluing the custom shim in works well.
1 - 2 of 2 Posts
