Hi, I have XUV 4x4 Gator and the wipers decided not to work this morning. It's a 2009 I think. I believe I am the 3rd owner. The service manual does not mention wipers at all, oddly enough. I checked the plug at the wiper motor with a multimeter and found no power in any of the slots. So then I checked the fuse panel and they all seem to ok, even though the service manual doesn't seem to indicate that the wipers have a fuse of their own there. So is there another fuse somewhere? Clearly there is no power getting to the wiper motor.
If it is wipers with switch up on roof line ,there is a fuse behind the panel ,or some have down near battery ,you will see a little relay and fuse together, that runs up cab post to wiper motor.
Also many switches have fuses incorporated. If there is a rubber flap next to the rocker that's part of the switch module, that's a fuse cover.
Curious if the OP minds sharing what they've found. Doing so can help others with similar issue and to close this thread.
