1 - 12 of 12 Posts
I have some lights and a day star light switch that I am going to install. Do I need a relay or can I just wire directly between lights, battery and switch?
What is the wattage of the light and the amp rating of the switch?
Lights are 27w LED and switch is 20amp rocker switch.
If you want to use the lights when switch is off then yes you can just wire from the battery to the switch to the light.
You mean when the key is off?
Yes sir
Thanks for your help! I'll keep everyone posted on how the lights turn out.
I wired all my LED Lights key on power ..Ground Controlled Thru a 5 Pin Relay....That's the safest and best Way...Just Time Consuming :)
Yes Relay is all ways the best 30/40 amp is standard for lights, horn, and so on so you don`t burn out the switch enjoy and have fun
Tat...If your switch is rated for 20 amps and your lights pull approximately 2 amps how will you burn the switch out?
Fred... can you please explain Ground controlled with pin 5 and why that is the best way?
I not disagreeing or attacking...I'm just trying to learn and understand better...
Thanks guys.
Discussion Starter #11 (Edited)
Install finished and they are BRIGHT! Can't even really tell when the factory lights are on.
Thanks guys.
So you can take a Relay have it Carry the Load and your rocker switch be the Ground...Hence Ground Controll...Mainly used for Higher amp requirements....I use it for all my applications..Takes a lot of time and more wiring and I also Soder all my connectors with Shrink Tube..I work in the Automotive Field and this is a Solid method of Electrical installation
1 - 12 of 12 Posts
