Hello interweb Gator experts. I've had a XUV550 for about 3 year now, with 600 hours, and it has been the tale of all things that can go wrong, did. New head gaskets, new clutch and belt, new seals, shifting cables, parking cables, shifting levers etc. Basically every other post on this model and it's happened to me. So my recent failure is the rear transaxle. We noticed a new "bad sound" coming from the 4 wheel drive transaxle that transfers power to the front differential. Got it in the shop and took out the transmission and sure enough, 3 broken teeth on 31T frontdrive gear. SO.......good ole JD will only sell me the tranaxle as a unit at $2200, which is insane for the amount I've got poured into this POS already. Luckily (if that can actually happen) it did not damage the 18T front drive gear that come out of the transmission or dump a bunch of metal into the mix. We were able to find the pieces and clean the housing. Long story short, I'm looking for a solution to replace the 31T gear. I haven't been able to find it on the interweb. I've looked at the salvage shops that have parted some 550s out, but this seems to be the most used piece, as I'm sure I'm not the first and it typically is not listed. So I'm asking the greater Gator community for suggestions. So far my options are:
1. Buy the $2200 transaxle.
2. Miraculously find a replacement gear
3. Grind the teeth off the gear, reinstall and forgo the 4 wheel drive forever
4. Repair the gear? (Can this even be done?)
5. Sell it for parts and buy something that actually works more than its broken.
6. Someone here will have the perfect answer that I haven't thought of.
Most appreciative of any ideas and hoping the answer is easier/cheaper, than it appears from my view.
