There's no weight or load rebuilt motor dont have bed on yet revs up fine in neutral no odd sounds or back firing just any incline slight slows way downIt's 16HP so given the weight and load, I'd expect it to slow down a lot. My 855D and 865R are 23HP diesels and they slow down considerably. I put a turbo on the 855D and it only slows down 2mph going up my local hill now.
LooHave you checked the condition of the belt ?
Looks fine took cover off can rev in neutral clutch closes all way in high very little but well sit in place with brake and dig a holeHave you checked the condition of the belt ?
Don't have one its a 2013 550 xuv 570ccFYI. Belts have a minimum width specification. It can be found in the operators manual.
Don't have oneFYI. Belts have a minimum width specification. It can be found in the operators manual.
Link to operators manual below, also unlike automobiles the Date of Manufacture has little value if you should need to purchase any parts or manuals for your Gator. Deere uses the Product Identification Number or PIN for reference to their part numbers.Don't
Don't have one
A belt may look “fine” or actually be within the minimum specifications however; once a belt has been glazed it will no longer grab the clutch sheaves as it should and will degrade the performance of the Gator.Looked fine when putting it on dont no how old belt is
If you've never replaced the drive belt. Have a relaxing adult beverage first as it can be frustrating. Not that it's particularly difficult but it can be a annoying to get to. In addition to a Torx bit in a cordless drill for the body panels I found a 1/4" drive ratchet, several extensions & universal joint made getting the screws of the clutch cover a bit easier. Some are easier to reach from the rear of the machine. Then the top plastic won't come out. Put on some gloves, grab hold and convince it to come out. It will fit and so far I've not broken mine.
I have all the panels still off just rebuilt the motor and new carborator had to re jet it they sent it at sea levelIf you've never replaced the drive belt. Have a relaxing adult beverage first as it can be frustrating. Not that it's particularly difficult but it can be a annoying to get to. In addition to a Torx bit in a cordless drill for the body panels I found a 1/4" drive ratchet, several extensions & universal joint made getting the screws of the clutch cover a bit easier. Some are easier to reach from the rear of the machine. Then the top plastic won't come out. Put on some gloves, grab hold and convince it to come out. It will fit and so far I've not broken mine.
Do you have to remove clutch to remove the belt and install it when put old one on i put around the clutch i already had offI have all the panels still off just rebuilt the motor and new carborator had to re jet it they sent it at sea level
YesYou must be a private pilot or work on really old cars to even know what a magneto is.
Are you getting spark at the back plug?
Or I was took cover off to check the gap
