How should the turn signals and hazard flasher behave on a XUV 825i above serial number 080001, i.e., Gators with the lighted Carling switches? I just installed front turn signal lights and a BM26183 Deluxe Light Harness Kit in my 2014. The turn signals and emergency flashers work as expected, but the behavior of the lights on the switches seems a bit strange.
With the ignition on, both arrows on the turn signal switch are continuously illuminated. If I press the switch to the right or to the left the signals work, but both arrows on the switch just remain permanently on. I expected one or the other switch arrow to flash with the signals. For the hazard light, the top double triangle stays constantly illuminated. The only thing that changes when the hazards are activated the is little circular light below the double triangle flashes red. Do all 825i models with Carling switches behave this way? Thanks.
barry
My dad and I just installed this exact kit on his gator. I’ll check out how his switches act and report back.
Well, when I figure out how to post a video on this new site, or how to operate this new iphone.... I have two videos to share that shows what my factory installed light switches do and what my dad’s at home installed deluxe light kit and switches do.
Fantastic! Thanks Granger, this info will really help. You've got me curious about any difference in behavior between the factory installed light switches and the home installed deluxe light kit switches.
I don't have the blinker or flasher kit but the signals light up when I brake or go in reverse any idea what's going on?
