hi new to forum like your lift kit idea long term how is it working out and do you the product sku you ordered on the sight I found several on the sightI was having issues getting my 550 s4 on the trailer without bottoming out with my short ramps. I used these brackets to get 1 3/8" of lift on all four corners. I run 26 inch tires on a stock steel rim with no issues. 4 adults and 400 lbs of wild pigs in the back and good clearance on some creeks crossings and fire roads. I run the shocks at the middle notch and happy with the ride.
Easy bolt on solution and so far no issues with my axles and CVs. I measured 1 3/8" down on the bracket and drilled a new 1/2" hole then trimmed the excess. I used a washer on each side as you see in the picture.
Not bad for less than $100 and no welding, hardware comes with the brackets. 20 minutes on each corner for the install and about 20 minutes to modify each bracket with a drill and grinder with a cutoff wheel. you will need an 18MM wrench and socket for the stock bolt and nut.
MaxTrac Lift Parts - Shock Extenders - Chevy - MaxTrac Suspension Store
[email protected] I think we can help 🐊I have a 2012 xuv550 s4 and I need this thing higher. Anyone out there lifting these?
www.UpliftSxS.comhi new to forum like your lift kit idea long term how is it working out and do you the product sku you ordered on the sight I found several on the sight
which one did you order thanks
www.upliftsxs.comUpdate, the lift for the 550 won’t work, so I cranked up the shocks and problem solved
[/QUOT
www.UpliftSxS.com
[email protected]
www.UpliftSxS.com[email protected] I think we can help 🐊
