I seriously considering getting a front lift kit for my XUV590E (see pic). I got the instructions from the potential seller. However; the instructions must have been made in China cause I can’t make sense of it. The instructions do make clear that one end is attached on the top strut mount and other end attaches to chassis but fails to state where on chassis. I have vigorously searched the Internet for videos but zero luck. Will someone please help out with this? IMG_4263.jpg
Have you tried contacting the manufacture? Perhaps they can answer your questions?
I installed a kit from the same mfg on my 825i, they are top quality!
@bama21fs - These are a pretty straight forward install. The lift kit bracket will bolt into the holes vacated when you remove the upper strut bolts. Then the struts bolt into new holes on the lift kit bracket.
